STD Tuning Engine OM 603 pistons/rods in OM 606 N/A
mwoodland
03-30-2012, 02:42 PM #1
Title says it all.
I've searched this and other forums and can't find the info.
Will the OM 603 turbo pistons and rods work in the OM 606 NA block?
The N/A already has the squirters, and my understanding is the pistons and rods are the weak link.
I have a 606 N/A, and have located an '87 603 core, from which I've already liberated the turbo IP...
Any info or BTDTs would be much appreciated.
I'm also looking for a 606 exhaust manifold, if you can tell where this is going..
Best regards,
Mark
mwoodland
Title says it all.
Best regards,
Mark
aaa
03-30-2012, 04:03 PM #2
The top of the 606 pistons look to be designed for 4 valves.
I'd be tempted to use the NA ones as is, if it were just stock turbo power levels.
aaa
jeemu
457
03-30-2012, 04:14 PM #3
603 pistons not good to use at 606.
606 weak link is not the pistons. Rods are the weak link.
I have drive and dyno 470hp on N/A pistons on 5syl.
This post was last modified: 03-30-2012, 04:15 PM by jeemu.
jeemu
erling66
SuperDieselVan
294
03-31-2012, 02:22 AM #4
For me the 606N/A rods and the 603 turbo rods looks to be the same so I don't think the older turbo rods are any stronger. 603 pistons will not fit. So use your 606 N/A rods and pistons. They will probably work fine unless you are going for high boost and rpm. I have 606 turbo exhaust manifold for sale but it will be cheaper if you can find one in USA.
HuhCoolTongue
erling66
HuhCoolTongue
aaa
03-31-2012, 08:29 AM #5
Here are the 603 and 606 rod specs ("Testing, repairing connecting rod"), the 603 turbo and 606 NA are indeed pretty similar, although still different part numbers:
http://w124-zone.com/downloads/MB%20CD/W...Engine.htm
aaa
yatzee
04-12-2012, 09:58 AM #6
are rods off an OM606 Turbo and a OM603 Turbo roughly equivalent? Would they both be an upgrade for a OM606NA?
1991 350SDL, burning oil and slow
1991 500SL, yet another project car
1984 190D, swapped 3.6 m104 with a megasquirt
yatzee
George3soccer
04-12-2012, 11:07 AM #7
606 turbo rods are much stronger then 603 Rods.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
jeemu
457
04-12-2012, 03:33 PM #8
(04-12-2012, 09:58 AM)yatzee are rods off an OM606 Turbo and a OM603 Turbo roughly equivalent? Would they both be an upgrade for a OM606NA?
606 turbo rods are stronger than 603 rods and both are 28mm piston pin
and N/A is 26mm pin.
jeemu
yatzee
04-23-2012, 09:41 AM #9
So to strengthen a 603 block, I'd want 606 turbo rods with 603 pistons?
yatzee
George3soccer
04-23-2012, 11:50 AM #10
Yup, that would make you over pass the known breaking period in a normally stock 603. which is rougly 350hp, I think so, not 100% sure about that.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
erling66
SuperDieselVan
294
04-23-2012, 12:15 PM #11
(04-23-2012, 09:41 AM)yatzee So to strengthen a 603 block, I'd want 606 turbo rods with 603 pistons?
The thing is: how to get 606 turbo rods? new are very expensive and to get used, you will probably have the buy the whole engine(606 turbo) and then you can use that one and forget about the older 603Smile
HuhCoolTongue
erling66
HuhCoolTongue
George3soccer
04-23-2012, 02:12 PM #12
How about off the shelf rods. Possibly some gasser motor built rods, or H-beam rods, that have very similar piston pin diameters. That need a small amoun of machine work to make fit for cheap.
I am big into the m102 16vlv coswrth world. And someone mentions some type of built Lexus v8 motor rods were very similar to the m102 motor rods specs that were very well built for much cheaper than stock rods or built stock spec rods.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
yatzee
05-08-2012, 03:13 PM #13
I just bought a set of 606.962 rods off ebay... Can't believe the deal! Now I need to find pistons....
yatzee
jonbobshinigin
05-09-2012, 07:10 PM #14
Dude...you got a killer deal on those rods. I need to find a deal like that one day!
1987 300TDT - 260,000 Miles
jonbobshinigin
