7,5 mm Element design for high performance engine
Here it is, first picture of the 8 mm camshaft for OM606 pump. This one gives 1 mm longer lift, I need to have a bigger roller also, Rollers comes from 14,40mm to 16,10.
Normal is 15-15,6mm in pumps.
I have some 17 mm rollers from Bosch A-serie that can be modified, but then the roller house needs to be grinded out a bit = weaker roller, no good.
Rollers are in different diameters for adjusting the phasing degree between the lines.
0-60-120-180-240-300 +- 0,5 degree
Tests will be made this summer, I have grinded 3 shafts for 6 cyl pumps.
Maybee a "monsterpump" soon comes to life?
Recepie is like this
8mm element
8mm stroked camshaft
Custom made deliveryvalves from VP37 pump
6000 rpm governor
Outside ALDA for easy adjustments
EDH_Performance 4digit power output?
