7,5 mm Element design for high performance engine
Duration,
I dont know if you guys think this is some kind of overkill, but here are the facts on my elements.
I only take a few points here, this is so you can see the difference between the 3 types.
First is 6 mm stock OM606
Second 7,5 serie 1
Third 7,5 serie 2
Speed is 1000 pump rpm.
All degree are pumpdegree, double up for engine degree.
Rack /mm Fuel /cc Degrees
10 40 12
13 60 14,5
16 83 18
19 105 19
10 72 11,5
13 95 13,5
16 120 15
19 144 17,5
11 74 13
13 100 15,5
15 121 18
18 150 22
21 182 26
__________________________
As you can see, serie 1 is quicker, at 72cc, it needs 11,5 degree to complete the injection, serie 2 needs 13 degrees for the same amount.
Here is also the answer to why the engine is so difficult to drive, it raise the fuel so fast on so little rack, that makes it sensitive on the throttle.
A small push on the throttle and BAM 100% moore fuel that stock.
Serie 1 is to prefere if you are satisfied with 350-400 bhp, if you need moore fuel, serie 2 or 8 mm is the answer BUT it needs longer time to inject = have to move injectiontime on engine.
Look at 6 mm @105cc, it need 19 degrees compared to no1 that goes on app 14 degrees
