Another car, chicago, uhhh 300d turbo w/4 speed manual
Ok so i drove the car 90 miles to get it home. No heat. No powersteering. bald tires. Cold night for sure. Put a power steering belt on today and hooked up a hose to give the car blowjobs to turn it off. Don't know if the vacuum pump is bad or just leaking vacuum lines. There is so much disconnected goofiness about the car. Uploading pictures so you wonderful peoples can give me some insight.
Again I feel lonely here in chicago, anybody nearby with and STD?
Also compression readings are right around 400 in all cylinders with not much blowby. I feel like I got a steal on having a car with 617 turbo and 4 speed manual for 1650$ what are your thoughts on that?
Can I put a EGT sensor in anything blocked off here? Has anyone while plating off the EGR valve set up a EGT through there? I read on that and it didn't look like anyone had. Thoughts?
pictures
1
2
3
4
5
6
7
8
9
