My OM617 Build
My OM617 Build
-Plate is in. Need to countersink, tap, and ream the holes. (M12 and M10 reamers ordered.)
-Need to install it on the engine, then check runout vs the chebby bell
-Fit drilled flywheel, and test fit mercedes starter vs chebby 14" clutch. Cut out mounting hole, add to DXF drawing
-Buy a 12" chebby clutch (90s camaro?) and test fit vs the starter again. I'd like the plate to be able to use either.
-Source pressure plate, pilot bearing, shift fork, throwout bearing, etc. and test fit.
-Profit!
FYI-the bolts that hold the trans plate into the block are M10x1.5 This also goes for the 603
