My OM617 Build
My OM617 Build
I was going to put the compressor on a pivot to tighten the belts, any reason I shouldn't?
The merc flywheel sticks out a little, and the ford bellhousing is pretty deep. I will probably be able to get away with a 1/4" or 1/2" plate. I have an old sheet of both on hand
I'm going to run an electric vacuum pump from an F350, they're ~$75. Ideally the shutoff will be a good old fashioned choke cable. I might swap in a bigger master cylinder for manual brakes as well.
Locating the pilot bear is going to be fun, the transmission weighs a good 150#, it has an integrated transfer case
