STD Tuning Brakes 124 brake upgrade
124 brake upgrade
124 brake upgrade
oel_brenner
04-19-2009, 09:27 PM #1
just finished up brake upgrade on the 124
swapped in brakes from a E420
in the front upgraded to 294 x 25 rotor and the four piston calipers
from the stock 284 x 22 rotor and the stock caliper
in the rear upgraded to the vented 278 x 24 rotor with the dual piston caliper
from the solid 258 x 9 rotor and single piston caliper.
also installed teflon/stainless hoses.
while its not quite the E500 brakes, the new braking performance
is absolutely breathtaking..
old rear subframe / new rear subframe:
[Image: brakes.sized.jpg]
brake lines:
[Image: brakeslines.sized.jpg]
This post was last modified: 04-19-2009, 09:28 PM by oel_brenner.
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
brake lines:
cars
trucks
boats
04-22-2009, 05:25 PM #2
Where did you get the hoses? $?
oel_brenner
04-22-2009, 05:32 PM #3
(04-22-2009, 05:25 PM)winmutt Where did you get the hoses? $?
had them made up at the local hydraulic fab joint
http://www.amazonhose.com/
$80 for all four
he made them up while I waited..
no shipping Big Grin
basically the same parts as what this guys sells
http://www.wrxtra.com/catalog/index.php?cPath=32
cars
trucks
boats
oel_brenner
$80 for all four
cars
trucks
boats
squirrelmaster
smokey
49
11-03-2009, 06:44 PM #4
Hi my name is andy I Would like to know if the whole e430 subframe bolts on to a w124 300d my car has a 5speed from a 190 2.3 16 valve, i am drooling over those giant rotors, and Is that diff from the 430 have Lsd? Whats the ratio, if possable i will put a subframe, brakes and diff from one in my car. Thanks please get back to me.
(04-19-2009, 09:27 PM)oel_brenner just finished up brake upgrade on the 124
This post was last modified: 11-03-2009, 11:34 PM by ForcedInduction.
squirrelmaster
oel_brenner
11-07-2009, 11:02 AM #5
(11-03-2009, 06:44 PM)squirrelmaster Hi my name is andy I Would like to know if the whole e430 subframe bolts on to a w124 300d my car has a 5speed from a 190 2.3 16 valve, i am drooling over those giant rotors, and Is that diff from the 430 have Lsd? Whats the ratio, if possable i will put a subframe, brakes and diff from one in my car. Thanks please get back to me.
you may want to check out this thread:
http://www.superturbodiesel.com/std/124-...t-325.html
cars
trucks
boats
oel_brenner
cars
trucks
boats
