Lights?
Lights?
Im surprised nobody has called Mike on his "knowledge"of LED vs incandescent bulbs. LED lights as designed don't generate heat like incandescent bulbs. Incandescent bulbs use 21 Watts to make those 500ish lumens whereas a decent 1156 bulb will useless than 3 Watts to produce 160 lumens. 1/7th the power, 1/3rd the light (but in the correct color spectrum). The way the LED bulb is more efficient is that it doesn't produce heat as a byproduct of light output.
If mike was melting taillight lenses, he had other problems than his bulbs.
