02-11-2016, 09:44 PM
#640
ANYway... update: fixed the following:
1) The high beam was not working because of the fuse. Replaced the fuse with a spare I had on hand, will try clean the contacts and replace all the fuses later.
2) The driver's-side foglight wasn't working because the plug was wired incorrectly, so I swapped some wires and that fixed that.
3) There is a chip in the driver's-side headlight lens, so I ordered one on eBay from some dude in Latvia. Should be arriving next week.
Things still left before I sit back and wait for the spring before continuing:
- Driver's-side turn signal has some wiring issues. I get power for the blink, but nothing for the parking light, and when I plug in the bulb, nothing works. Need to swap in a bulb from the right to make sure that that's not contributing to the issue.
- Driver's-side rear taillight is out. Hopefully that's just a bulb issue.
- Change oil
- Adjust valves
- Fix GP wiring
- Get spare tire
- Pull damage from rear
- Replace hood pad
-Jooseppi
1979 240D 4-speed 234k -- turbo and tuned IP, third world taxi hot rod
. Given to me by JB3, who got it from purplecomputer.
Some blasphemous vehicles in the fleet as well -- 2004 Corolla 5-speed and 1994 Buick Century
2 Samuel 12:13: "
David said to Nathan, “I have sinned against the Lord.” And Nathan said to David, “The Lord also has put away your sin; you shall not die."
