Purple turbo 240D
Purple turbo 240D
When you cut the stock springs they get stiffer less coils = more stiff The 240d springs should work nicely cut a little at a time and use a cut off wheel easy way is to jack it up use a spring compressor and then cut it take the compressor off lower the car down roll it around to settle the suspension maybe Evan drive it around the block and repeat until you like it. I would start with 1 coil. and probably wouldn't go past 2 coils total.
This way you get practice before you botch up a pair of 300d springs the 300d spring will make it ride very high up front and will need way more cut off than the 240d springs.
if the 240 springs and Bilsten shocks are not stiff enough then try the 300d springs but I think you will be happy with the 240d springs and the hd installed
