Purple turbo 240D
Purple turbo 240D
1. Buy at least 4 gaskets that go between the IP and the block.
2. Think about buying a gasket for the IP shutoff pod
3. beg borrow make a timing tool. spare line is easy peasy
3. Buy a brand new paint marker
4. Make sure you have a small sharp chisel.
Look for a witness mark on the IP, if there isn't one add one with the punch.
The redneck way is to rotate towards the engine, test, and if it knocks retard the timing.
The right way is to:
-chisel witness mark the IP
-paint marker the shutoff pod so you know which way is open and closed
-Set engine to the timing you want (26-28BTDC)
-remove teh IP lines
-remove the shutoffpod
-remove teh $@#!$!@#$!! bracket from the back of the ip and don't lose any bolts
-remove oil line from IP
-Fuel lines too
-remove Ip bolts, pull IP
-scrape gasket stuff off
-new gasket in, oil it up to make it easier
-line up pump marks
-do the drip thingy
-tighten shit down, test drive. if it knocks, retard timing (rotate away from engine)
