Purple turbo 240D
Purple turbo 240D
Those rubber brake lines can dry crack, bubble, or internally delaminate causing brake drag or other problems.
They are getting on in years, so problems are more likely, so it was probably a good bit of preventative maintenance to take care of them.
Sucks that you have have to replace the steel line, but at least the driver side is a lot shorter and should be easy to replace it
