Purple turbo 240D
Purple turbo 240D
You would kinda be the guinea pig. The brake booster is the largest consumer of vacuum (assuming your door locks don't leak) so you should in theory be good just hooking it up. If the pump isn't big enough, or if you were braking a lot, you would need a reservoir or a bigger pump. Probably not the answer you're looking for but that's it. You can also get a bigger MC and go manual brakes.
