Purple turbo 240D
Purple turbo 240D
(08-16-2012, 02:46 PM)willbhere4u You can also adjust the ADA top of the injection pump by loosening the 10mm nut on the top and turning the flat head screw in the middle out several turns CCW and then tightening the nut back down. or you can also remove the whole thing and get the same result
I turned my screw all the way out CCW and then tightened it and it helped out a lot.
This affects how much fuel it gets ccw gives it more fuel. But it may smoke a bit more!
usually it is adjusted not smoke. but with the turbo and all of the extra air I would not worry to much about smoke. Evan maxed my car barley smoke's at idle only
