Purple turbo 240D
Purple turbo 240D
That's the oil separator, turbo models have that inside the aircleaner. Where are you putting the normal 240d oil separator? If you're keeping the 240d one you can ignore the one in the aircleaner. If you want to use the turbo oil separator then you will have to deal with the different blowby oil drain, you can see the 240d drain is in a totally different spot.
