Purple turbo 240D
Purple turbo 240D
I am making good progress on my turbo conversion. Couple of things to note. If you have the York a/c compressor it will not fit with a turbo conversion, you will need the newer r-4 gm compressor and bracket that mounts under the power steering pump on the drivers side.
throttle linkages will also need to be changed, notice your linkages come up through the intake/exhaust manifold. they will not fit once the turbo is on. I'll figure what I am going to do this weekend.
New engine is in now, just need to finish little stuff. Might take the complete exhaust off a 300, it's the easy way. Don't worry I do have two down pipes, so if you still want one I do have an extra.
