(09-05-2011, 07:45 PM)DeliveryValve Looking good! Thanks for the posts. I think the 722.608 is the better trans in terms of gearing if cost is a wash.
Thanks! I'm trying hard to make this a success!
Cost isn't a complete wash - sorry if I alluded to that. Here's why:
The 722.608 has expensive hard parts - and I'm not
exactly sure what is needed in order to upgrade to handle 500-600HP. The only differences (other than the bellhousing) between the diesel version and the version behind the twin-turbo V12's is the number of clutches in a few different clutch packs, number of sun gears on one (maybe two...) planetary sets and the number of clutches in the torque converter. Fitting more clutches into a given clutch pack often requires new hard parts. Luckily, the diesel variant of the 722.6 is halfway there to being upgraded to V12 status. I have 2 different rebuild manuals for the 722.6/W5A580 and it seems to be a VERY simple transmission...something that I like very much.
The 4L80E has very cheap hard parts and nearly every transmission shop and vendor in the USA has these parts in stock. The 4L80E is a bit more complex mechanically to make up for the fact that it was built before modern electronics were good enough to shift a transmission with no bands and only clutch packs and planetary sets (like the 722.6).
Such is my mania, although I'm currently agonizing over finding the right intercooler. I have a roughly 22x20x3 space to fill, so that should provide decent surface area. Finding a pre-made core with those dimensions is proving to be difficult. I'm even contemplating going the air:water route... That's the beauty of this project - I can go any route I want, within reason.
Beers,
Matt
'07 W211 OM642
'95 W124.131/722.435, 211k - daily driver/Superturbo project - OM606.962 with "M" pump...under construction! (build thread
here)
