STD Tuning Drivetrain stiffening up manual transmission linkages?
stan
04-15-2011, 01:19 PM #1
after spending a bunch of time with my 240d apart, i see why teh 4spd feels so squishy. both the transmission and shifter ends of the linkages have big squishy rubber bushings that i hypothesize are the source of the mushy shifter feel.
looking at the linkages, it seems like it would not be too hard to make either metal or urethane replacements for those bushings on a lathe. you'd probably need to make them 2-piece or get creative somehow to hold them in position, but i think it would be doable.
has anyone else thought about this?
stan
04-15-2011, 02:10 PM #2
The 190rev guys put brass there instead.
04-15-2011, 04:05 PM #3
Viagra
Viagra
300D50
Graphite Moderator, ala RBMK
04-15-2011, 04:48 PM #4
Hah, very funny, specially since it's a tranny!
300D50
stan
04-16-2011, 03:33 AM #5
captain gives his trannies viagra dontcha know
stan
04-16-2011, 08:34 AM #6
heres a thread with some pics of removing those bushings and replacing them with brass-
http://www.superturbodiesel.com/std/thre...ing-shifts
I did a super hack temporary experiment on my 240 by replacing the rubber bushing under the stick handle with 12 dimes instead. made shifting a bit stiffer, but also clunkier. You should start with the bushings on the tranny and see what happens.
300D50
04-16-2011, 07:34 PM #7
The dime method is awesome, saw it first-hand!
I'd wrap it in electrical tape till it fit perfect, then go from there.
300D50
04-19-2011, 09:14 AM #8
My 124 had hard nylon/teflon in there on the shifter ends of the linkage. Cheap and easy to work with.
Oil Burner
Turbo Everyting!!!
83
04-19-2011, 09:36 AM #9
Has anyone tried to cut off the Mercedes ends and just tread the rod and install small Heim Joints You can get those at any tractor supply and that would stay true for allot longer and would not bind.
Oil Burner
