Toyota pickup OM617 swap
In my experience, as long as the in-tank pump is running, you're good.
You can add a swirl pot/surge tank at the firewall and have it recirculate back to the tank, then have the engine return and the feed to the lift pump go to the surge tank.
Put a water separator with a rough-filter off the tank pump before the can, and you'll have constant filtration of the fuel in the tank, and a mild heating effect in the winter time.
