stan's 240D
stan's 240D
had a busy day at work, so no parts got picked up, but i'm eyeing out some stuff in the meantime.
on the vacuum lines, my ignition supply / shutoff valve lines are correct, my door lock and vac res lines are correct, but i found two danglers. one is black with a yellow strip, i believe that's a cruise control (which i removed) supply line as it doesnt go into the firewall and isnt hooked to anything. the other is coming from the port below the fusebox and is much thicker but still the same plastic material, and has a gray plastic nut at the end. what is that?
