Prechamber Mod "Flame" Front
(01-25-2011, 02:59 PM)casioqv This is a very interesting thread to read, but I feel like one practically needs a mechanical engineering PhD to make a useful contribution... so pardon my ignorance posting without one.No can cut tip of. Also it runs bad if you remove the "pearl" inside the chamber
I wonder how these engines would run with the entire tip of the prechamber cut off, to essentially make them nearly a direct injection motor. I realize one would probably lose the entire upper rpm range, but would we gain more torque and efficiency like a DI engine?
If the engine were overall more efficient running at lower rpms with more torque, perhaps you could gain back the lost horsepower from the narrower rpm range by simply running more boost and fuel while retaining the efficiency improvement.
//edit: OR would the geometry of an IDI engine with the prechamber opened up make for a very poor running DI engine- having the injector way up inside a tube rather than spraying right into the piston? I suppose there's other differences too- I'm not sure why DI engines always have such low compression ratios compared to IDI ones.
Overall it actually sounds like IDI engines are better for high performance, but DI engines may be better for normal driving where efficiency and torque trump peak horsepower.
