(01-24-2011, 09:05 AM)ForcedInduction Okay then, lets see your ASE paper.
(01-24-2011, 10:36 PM)dieselboy That paper will work great for tp if you happen to run out.
LOL!!!!!!.... your killing me here..
But respectfully, the report does have some good measurement data.
I was just thinking, Jeemu's engine has smaller displacement cylinders compared to the 616 and 617. If you compare the 61X prechamber to the 60X prechamber, the first thing I notice is the 60X prechamber has a lot more holes of pertinent size, which go all the way around the tip, where the 61X prechamber has only 3 serious holes, two about 1/2 the area holes on the back side, and a tiny one in the end. The 60X can expel gasses 360 degrees because the prechamber is straight up & down, and is basically centrally located in the cylinder, where the 61X prechamber is on an angle to one side of the cylinder.
The point is if you add up the area of the 60X holes, (especially Jeemu's enlarged ones), and ratio the area to the displacement of the cylinder, and then take the area of the 61X holes and ratio those to the displacement, I wonder which engine has a better hole area to displacement ratio.
I need to look through my manuals and find the hole specs for the 60X engine. I may still be on the conservative side. Just trying to come up with comparable data that can be referenced to a known.
