Electronic variable vane control
(03-19-2009, 11:45 AM)GREASY_BEAST I agree that electronic rack control would be ideal, just not worth the PITA of relocating the oil filter without a good reason (like a Myna pump), which it doesn't seem that anyone around here has.. Basically, and maybe I'm just being narrow-minded, I don't see how it could help appreciably on an IP with stock components, other than adding a certain level of engine protection, some more advanced smoke control, and other superfluous things that don't make the car go faster.
(03-19-2009, 11:45 AM)GREASY_BEAST I'd agree with that, and go so far as to say even electronic wastegate control on a "normal" turbo might yield some benefits like quicker boost rise and more stable, accurate control over maximum boost, cruising vs performance settings, etc.
(03-21-2009, 09:54 AM)GREASY_BEAST Might it be possible, with an Arduino board and a voice coil actuator, to remove the mechanical governor and make governance of the engine an electronic affair?
(03-21-2009, 09:54 AM)GREASY_BEAST The software would be dead simple to write, I'm pretty sure with my limited experience I could do that in an afternoon
(03-21-2009, 09:54 AM)GREASY_BEAST The weak link (I guess) would be accurate sensing of the engine RPM?? Could one just use the tach sensor for this or would you need a more accurate reading?
(03-21-2009, 09:54 AM)GREASY_BEAST Another weak link might be the sensitivity of the actuator?
(03-21-2009, 09:54 AM)GREASY_BEAST Would it also reduce the cost of swapping elements? It seems to me that there would be a lot less "shop time" billed by an injection shop if all they had to do was make sure each element is synched to all the others, and not mess with the governor adjustments.
(03-21-2009, 09:54 AM)GREASY_BEAST Just a brainstorm..
