(01-30-2014, 09:31 AM)JB3(01-29-2014, 01:52 PM)Simpler=Better Alternatively, hold a marker up to the flywheel as it's loping around. The outermost flung area will hit the marker.
EDIT: setup a camera when you're doing this just in case. That way your wife knows what happened when she finds your body.
hahaha
you and your schemes to get me hurt or killed. I don't think the wife will appreciate your efforts!
although this is not a bad idea...... But id really need to lock the marker in a jig that held it exactly in the same place.
(01-29-2014, 02:07 PM)willbhere4u 1st check the balance on the original 617 flywheel it may be neutral balance I have read that a 240d 616 flywheel Evan balanced and matched will vibrated on a 617 because it dose not have enough mass for the 617 engine. The 300d manual flywheels are massive and very heavy over 50# loaded I believe. On a diesel the heaver the flywheel the better for vibrations concerns!
I just did a test to see on the original flywheel-
check this out, its got a definite heavy side.
http://www.youtube.com/watch?v=QAX6FiShQ...e=youtu.be
I was told the aluminum flywheel from the kit has a neutral balance, but now thinking on it, im not sure. I can't remember any drill marks indicating its been balanced. Once thats out im going to spin that too and see what it does.
Maybe I have a biased weighted flywheel incorrected installed on a engine that already had a biased weighted flywheel. That could explain a lot
(01-29-2014, 10:46 PM)Austincarnut try and figure the heavy spot and counter with stick on lead wheel weights (if there is space) and then adjust by removing material
good idea, ill start playing with it after I build a jig so I can see the flywheel in action. Im really interested to see what it looks like running
hahaha
