Ok, I have good news, a little more good news, and a serious blunder that will now be very difficult to resolve.
good news 1-
I have eliminated the metallic noise, there is no more clicking and destruction noises. It seems this was again, the flywheel contacting the adapter plate bolts.
good news 2-
the clutch is now working quite well, so finally have that worked out.
good news 3-
the big tires look good, and only barely touch on some corners. I still have to put the wheel stops in, but they should work well. Secondly moving the bumper up has totally improved the look of the van by a huge amount.
comparison of before and after-
and now for the blunder. I make this admission because this is a crucial step I would never had made doing a 4-speed conversion on a benz, but rocketed right along on this van blowing right by it without thought, and have made some huge work for myself.
It suddenly occurs to me what the vibration is at low RPM (and its major). Its because I neglected to match balance the big aluminum flywheel with the existing benz flywheel from the 617 motor. Not only did I forget to do that, I also removed the benz flywheel from the donor motor WITHOUT marking it.
This means that I am pretty much screwed here on getting the balance right with no reference marks. I must have been on the 616 mindset thinking neutral balance, but ive blown it big time.
I can't think of any way to get the balance correct short of pulling the crank out and re-balancing with the flywheel. Unless someone has a labor saving scheme, this is what I think will have to happen now. whoops. heh, this thread is now dedicated to doing every bit of the conversion wrong 20 different times, and hopefully getting it to work.
On the plus side, the crank can probably come out in the van without too much issue. Ive done it to myself this time, thats for sure
