ok, im giving the T5 another try.
Reason being is ive been sitting here with the gearbox turning it in all gears, and nothing, feels great. No clicking, no play, no nothing that would cause worry.
After I pulled the flywheel, I had a good look at the groove cut in the back by my first problems. I finally pulled up a comparison pic of how it looked the first time-
and now-
certainly looks like more, but weirdly, I can find no evidence on the bolts themselves showing they touched. It doesn't seem possible that they are making all that noise and vibration, BUT, its so close to my original issue, that there is definitely a likelyhood that this is the culprit. We will see
so what ive decided to do is take that 3mm spacer that I had moved to the front of the flywheel, and move it to the back where I had placed it early on behind the 616.
I moved it around to the front because that was how the kit was designed, and I wanted to move the pilot bearing adapter back by that much, but the clearance is so close, that maybe its touching under load, maybe the flyhweel itself is actually flexing just a tiny bit under load?
anyway, its worth a test install to see what happens with that spacer behind the flywheel again.
