(12-11-2013, 02:42 PM)Jooseppi Luna Simple shutdown:
Floor the brake
Put it into 5th
Pop the clutch
No?
yup, you guys are describing exactly what ive had installed from various manufacturers in this van already.
I first used a yard sourced vac valve, then a brand new MB vac valve (both overboost protection solenoids), then a GM EGR valve, same setup, Then a volvo vac valve, then a VW vac valve, then a HUGE fuel valve (not rated for vacuum though, worse than the others).
The situation is this, the methods you describe all work in theory, as ive tried them out, replumbed for double valve, single valve, and so on, tried various pinhole methods, ect.
The problem is that few of these valves are strong enough to work against the vac pump in the best place i can mount them, which is 8 inches from the pump. ( I know it shouldn't matter, but it does seem to have an effect)
Running conditions are, the valve gets pulled open by the vac pump on highway, creating power loss. (this happened with two valves, GM and fuel valve) The valve functions to turn the vehicle off and stays open when energized against vacuum so no power loss, but cannot pull against residual vacuum and reopen after closing, creating a very hard to restart condition, ect ect ect. (this happened with all valves)
The MB overboost valve is the most popular item people use to shut their engines off, and its the most consistently reliable and workable in my layout, and it still is subpar, requiring 30 seconds of key on to start, and so on.
Basically, Im sick of all this crap, and im going to see what the open vac line T is like now, as the simplest, crudest, and most reliable method of shutting off ive yet read about.
Floor the brake
Put it into 5th
Pop the clutch
No?
