took care of those two mounts-
Since I spaced the subframe, I had this going on with the transmission mount-
I had it hacked together for a while with a couple 3.5 inch pallet jack wheels as spacers, but this was perpetually getting loose, and was really just a temporary solution-
replaced the drop mount with a piece of 2 inch pipe instead-
Next issue was I needed to support the downpipe. The flex joint I had put in was a bit small, and instead of taking up some of the flex, was just transmitting vibration up to the bolt flange where the downpipe connects to the turbo flange. Either the downpipe was going to crack at the flange, or the turbo housing was going to be damaged, so I wanted to make a beefy support
