(08-15-2013, 03:20 PM)Simpler=Better Looks good.
The rubber bump stops were probably so you didn't crack the spring when it is overloaded. Or they were there to change the natural frequency of the springs to avoid resonance
(08-15-2013, 03:20 PM)Deliveryvalve I was always a big fan of those fiberglass springs. First thoughts were how corrosion proof they were.... Not!
I think the rubber parts are vibration dampers.
Looking good though!
(08-16-2013, 02:33 AM)Ksteen2 can you pos a video of it, and how it goes ?
4.56 did the trick! 1st sluggishness gone, can pull overdrive with good cruising note on highway, most importantly can do hill starts in 1st now. Very steep little hill near work, previously had to floor in 1st and nearly stall out on the top, now can pull 2nd up same hill and downshift into first at the top, closer to the 240. Gonna try long steep hill elswhere with stop sign at the top and see how it compares to my DD 240 sedan, which can pull second up that hill
Tradeoff is van is slightly slower, 1st gear is almost a granny gear now. Very pleased though, now can dial in and tweak the power output. Gonna test towing performance next week. The difference in highway note and feel is amazing, engine seems overall way more comfortable in all gears, theres less of a valley between gears if you catch my meaning, you don't have to wind it out in first to catch 2nd at a pullable rpm in other words
Another issue is now with this diff, the popping the clutch stalling method of shutting it off does not work in 1st. The torque multiplication makes that super violent, like throw your forward violent.
