(05-29-2013, 02:25 PM)Simpler=Better When wiring a car from scratch, if you can use overkill wire-always use it. Advance is crazy-their wire prices (when you buy the whole reel) are from like 1998.
For the offset hole, why don't you drill it where it needs to be, but 1/8" larger, then sleeve it back down with a 1/16" wall tube? That way you will seal the exhaust gases and don't have to cut it all up. It's a trick they used to do with bolt holes and valve guides in v8 heads that had thin walls when ported.
If you were closer I could bang that out no problem. Or if I was still up in the 'bucket, they had mills at work.....
