couple updates-
vac pump hooked up to stock GM line, still need to add a port for vac shut off when I get to that, but for now I should have power brakes when I test fire this sucker
New fuel filter installed, made a bracket to hold a 500FG racor fuel filter, huge leap over the stock filter that was for the diesel. Combined water separator as well, nice piece of hardware
also have the oil filter location mounted. Just waiting on a new oil cooler from summit right now, then I can get the three lines made up that I need. I probably already mentioned in this thread, but this moroso head has a provision for a pressure gauge outlet, and a small secondary output I can use for turbo oiling. With the exception of not having an oil thermostat, I should be able to do everything else that the stock oil filter did.
Was looking to adapt the MB oil cooler, but the one I have is so beat up it seems a waste of time making custom line ends to fit on it, so I went with a new one that already has NPT ports on it I can easily adapt to -10 AN
easy access-
one short line might be a bit cramped between the plate and filter head, but worst case scenario, I make a longer one and loop around-
glow plug relay mounted to GM airbox, this way the wiring harness for it is close to the wiring harness I will be creating for the engine. Fits nicely here though
