some updates-
Put this van in the air, and I thought it was in good shape for rust, but notice how the subframe is hanging on one side here-
driver side super rusty, not attached anymore-
4.3 ready to be dropped-
from inside-
dropped-
all the mount locations are rusty unfortunately-
after the engine was out, whipped up a jig to control stock ride height for the replacement drivetrain
with engine removed-
have some rust on the body to deal with, only part though, apart from some rust in the rocker that can be resolved after the subframe is put back up-
Using that jig, I set up the new modified subframe, and got the correct engine height for the diesel
working on motor mounts now.
Good news on the throttle, I should be able to use the stock cable throttle on the diesel without incident. Interesting, it circles around the entire engine bay, and comes around to the driver side of the engine from the passenger side. thing is about 8 feet long-
big issues to work out not resolved yet, steering and oil filter. lots of room for a remote oil filter here though, where the stock fuel filter was-
starter fits perfectly though. I was worried about the location in relation to the lower control arm on the passenger side
Engine is at the correct height using the jig, motor mounts look good, passenger side lines up perfect, driver side a little, ill be using the bracket off the 4.3 and adding to it.
driver-
passenger-
