(10-06-2011, 10:40 AM)Purplecomputer what kind of turbo will you be using on the 240D engine and how will you prevent it the turbo from ruining the engine? willbhere4u told me 10psi is the safest maximum load that wont cause damage to the engine, will you be doing the same?
ill be using a stock 300D turbo, which should put about 8-10 psi max hopefully. I saw that consistently in my older 300D
Ill have some time to tinker with it though, since it won't be in the van for a couple years or so. Maybe I can find something even lower psi that would work, but the custom manifolds will allow me to put any 300D turbo on the engine as if it would be stock.
Im thinking I need to be careful about this though with an EGT gauge, once this engine is in the van, the frame allows me to tow up to a 12x6 double axle trailer, which I have done many times. A low PSI turbo might not hurt the 240 engine just moving a car, but towing a load might/will seriously impact the EGTs with a negative result, whereas just the NA 240 engine would still get the job done without the risk.
we will see, since I started this thread, to give you an idea of the load ive been putting on this van, I managed to completely overheat my stock transmission on the van towing, blowing out the front and rear seals and forcing me to change fluids and filters, and put in new seals.
(10-06-2011, 10:48 AM)DeliveryValve Actually, it would be best to bubble and shrink wrap it and have no box. Then it shipped out that way. I know Greyhound would take bubble wrap parts. Not sure if they would take a 5x6x2 part though...
Lol, I was just joking, don't even consider it! You would have to completely break down the subframe to make it realistically quasi-mobile, removing all steering and suspension as well as the motor and ect ect. Unless you happened to find one standing against a van, no way it would be worth it, and even then, probably not
yard would probably charge me 1000 bucks in labor just to strip it down. Guy here is thinking about 400 bucks to fix it and paint it.
