IP Full Load Adjustment Procedure for the MW and M pumps
I do have low base pressure and am waiting on the new lift pump to come in so I surmise that is either whole or part of the miss issue.
So on a 616 is the theory to tighten the Idle Governor Spring Tension screw until the idle starts to creep up, like taking out play? or is it more of a balancing act where idle is increased with the Idle Governor Spring Tension screw then the fine / vertical stop backed off to keep idle in the target range until the idle is stable with or without a load?
