IP Full Load Adjustment Procedure for the MW and M pumps
Ok, I have a decent idle now. It's still high, but not too bad. Still the idle gov spring doesn't seem to be doing much, if anything. I turned the vertical throttle stop 2.5 CCW to get a decent idle speed and return to idle is actually good. The worst part is, I am back to the power I was before except the off the line seems better. The rack is 2.5 turns CW now, and that is as far as it will go. I guess the IP is one of the ones you hope you don't get if you want power.
