IP Full Load Adjustment Procedure for the MW and M pumps
Cut a hole and make a dome cap to cover the area and weld it on.
Do you guys make special sockets to adjust the IP? I took the cover off mine and there was a clip on the end of the torque control, is this normal to have a clip on the end of the shaft? I couldn't really do anything because of space, so I put it back together. I'm going to pull the IP since its pretty easy and adjust the pump.
