IP Full Load Adjustment Procedure for the MW and M pumps
That's good news about the pump modifications applying to the om603. Thanks.
Now, here's my goal. I'd like your opinion on how to arrive at it. I don't really want to go in and change any internals of the engine. IP maxed out with the stock 5.5s is fine. I am assuming that in order to make full use of the additional fuel flow one would need to increase the turbo size/volume, larger fuel pump maybe. Are you implying that the small stock turbo (set to max psi or thereabouts) could make big number power?
Seems these Finns are putting these big turbos on because the extra boost is needed. Maybe they do need the extra large turbo because of other mods to their engines to get to the 500hp range. That's what I'm trying to figure out.
I'm more concerned with low end grunt. I know that is generally not a turbos forte. But my trade off would be more towards good low end and give up some top end.
I know of cases where the turbo or turbos are put under the back of the car to help keep under hood temps down. Plus an intercooler isn't needed because the long run to the intake is effectively the "intercooler".
I would prefer to leave the stock turbo intact and add another smallish one to add that additional boost that seems to me would be needed to keep up with a maxed out 603 pump.
I'm quite new to turbos and that is why I'm seeking some experienced advice so I don't waste a lot of time with something unnecessary.
So please could you help me to understand what combination of changes need to be made to the engine to maximize the modified IP without overfeeding it or starving it?
Best regards,
Derek
