IP Full Load Adjustment Procedure for the MW and M pumps
(02-27-2010, 11:46 PM)Jettmar How much of the above text applies to that pump?Everything on the M-pump.
Quote:my car doesn't need to be that fast. I want to put a larger turbo or more likely add another to boost it without going overboard.Thats not really needed. The stock turbo can handle all the power your engine can produce without a myna pump. Compounds aren't of much use to these cars unless you live in high altitude, there is a good-match single turbo for pretty much any power level you want even up to extreme 500hp+ systems.
