Holset HX35 Install info on om603
(08-20-2010, 06:44 AM)ForcedInduction Yes. I have produced over 50psi backpressure on my engine . . .Come on. Your engine has nothing in common with OM606, except manufacturer and fuel. Besides you've got like 40hp/liter, how can you say anything about not-lacking-power-effects?
There is no data to suggest the 606 should perform differently.
Post a 605/6 dyno with an HY35 and show us how bad it really is.
(08-20-2010, 06:44 AM)ForcedInduction I know for a fact backpressure isn't a danger on the 606 due to the stock turbo.With stock turbo the boost peaks 12psi at low rpm and drops to 8psi at high revs. Why is this? Becouse with stock turbo, the backpressure would be too high even with such low boost. How about when its 30-45psi boost and similarly greater backpressure at high revs? Stock 606 doesn't pull hard 5000-6000rpm.
