You can remove the rack and make a couple of adjustments referenced in the pump tuning section. It is not that hard to pull the pump, just set thye engine on #1 @ 24* it will be easier to pull when you have the filter housing off. The adjustments are not hard, just takes a little patience - document, document, document is also recommended so you have a reference point to return to.
