EMS for electronic OM606 engines
This is a fairly simple thing to do. I was working on drive by wire with the PCS datalogger using the boost control feature. I could target a position based on throttle position with redundant tps signals. I see no problem running the diesel pump with this. It would be easier since you do not have to worry about return spring pressure etc. Not as twitchy. You could also use the rack position as feed back if you want. The most important thing is to have fail safes. I was also thinking of having it target a pwm with tps value and then have the other pwm output be a failsafe for rack position. Idle speed control would not be attainable though. You would just have to set a targeted pwm a little high.
