I did it 95 Turbo 606
Yeah! The world wants to know whether the rod bearing ever got unspun and how the compound he221 and k29 went! The hx35 was far too large for a good high pressure turbo, and the 221 should have been perfect. The 64mm compressor on the k29 is also a bit too small, actually, for good mass flow at PR of 2-3. So you might have painted yourself into a high boost corner there, as it needs to boost way higher to achieve good mass flow at higher rpm (assuming you still want a smokeless setup). hx52 is probably perfect - I think it is around 70mm compressor inlet. 60mm wastegate sounds perfect.
