I did it 95 Turbo 606
So I pulled the motor and trans last week. I have tore the motor down and all looks real nice even the bearings. I think the rings where just not seated good enough for 25lbs of boost and had to many miles. I am going to re-ring and new gaskets. I am also trying to find some aftermarket rods to support more power. I have sourced a good 722.6 so now will be looking for a e420 speedo and a shifter from a 129. I have a k29 turbo sitting in the garage and was thinking of a compound setup with the hx35 with a quick spool valve and the K29 switzer turbo for some real good numbers and less black smoke. I could do the valve and try to get 10lbs of boost by 2500 rpm and 30 by 4500 with the K29. The K29 has a split scroll and would do good with a nice quick spool valve on it also set for 30lbs.
