I did it 95 Turbo 606
95e300dez: Looking good. Built manifold at home?
So the turbo sits on top of your manifold, i'm guessing weld els for the manifold, a support bracket would be good to add anyhow. What's the size of that, ID is also a good reference?
Flange looks cut with a grinder or torch.
And how about the exhaust ports matching the flange on yours as it is a 4 valve, oval ports to round tube is a bit bad for flow unless you purposely add lots of weld material and then grind back..
I have access to CNC machines for having a flange made, and will be doing both a TIG and a MIG to weld, so mine will probably be a bit more refined. Making it car show neat as it is. No offence about your manifold.
How did you drill the return and get the shavings out? Without dropping the pan i see no solution other than flushing the whole sump in diesel or having a magnet on the drill. Even so flushing it would make me sleep sounder.
TA Stefan
