Craiglist alert thread
Quote:1984 Mercedes Benz
300 TD diesel Wagon
290,000 miles
$800.00
Needs: brake work
transaxle
battery
Will run
Quote:83 SD. 5 Cylinder turbo diesel. 380K+ miles. Runs and drives dependably. Not a cream puff. Would be a good car for someone who understands Benzs and or needs a running parts car. Ruff around the edges, I repeat Not A CREAMPUFF! $750.00 Firm 541-942-3649 or Email
Quote:2005 Mercedes 2.7 Liter Turbo Diesel Engine for core. This is a high mileage, rebuildable engine. It is not a running engine. This engine is due for rebuild. Selling at less than core charge pricing. $1000 FIRM. Engine block, head and internal hard parts are 2005. The injectors and fuel system are 2003. The injectors had about 3000 miles on them when engine was replaced. Fuel rail, injector lines, oil filter housing, oil cooler and intake are included. Aluminum engine mounts are from a Dodge Sprinter. Oil pan available too. We also have a front crossmember, control arms, Charge-air cooler, aluminum wheels, tires and a few other pieces available. Dodge dealer's charging $2000 core charge on these engines so I would think $1000 is a smokin' deal condsidering the newer injectors. Harmonic balancer and a good starter ring gear is included. NO starter, NO alternator.http://grandrapids.craigslist.org/pts/1668435628.html
1984 Mercedes Benz Wagon - $800 - minneapolis
300 TD diesel Wagon
290,000 miles
$800.00
Needs: brake work
transaxle
battery
Will run
