STD Tuning Engine Correct location for EGT probe?
ho55
09-16-2015, 05:15 AM #1
Whats the best / correct location for an EGT probe on the OM606.962?
I have it mounted in the blank plug from the removed EGR pipe at the moment.
ho55
09-16-2015, 05:20 AM #2
Anywhere before turbo, nearest to where it would see all gas flow is best (for averaged cylinder temp).
09-16-2015, 01:32 PM #3
egt well , yes it is where i have mine!!! and many other .....
09-17-2015, 10:26 AM #4
I drilled & tapped directly into the iron (605)
[Image: photo4.jpg]
[Image: photo4.jpg]
50harleyrider
GTA2359VK
397
09-18-2015, 06:54 AM #5
Nice turbo adapter Hario. It looks like it has more flexibility than fixed one like DPUK sells. Where can I buy one similar?
This post was last modified: 09-18-2015, 06:54 AM by 50harleyrider.
50harleyrider
09-18-2015, 08:55 AM #6
Mine:
http://www.superturbodiesel.com/std/show...p?tid=6734
Ohh, I just saw you are in the US of A..
I uploaded the flange drawings herehttp://www.superturbodiesel.com/std/show...p?tid=4939 get them laser/water/plasma cut for real cheap, then buy 2.off: 2" ID weld-els from your local steel merchant, then buy: a 2.5"(IIRC) ID V-band adapter from your friendly parts store and get an even friendlier welder friend to mig it together for you for beers.
That is what I did.
Smile
(09-18-2015, 06:54 AM)50harleyrider Nice turbo adapter Hario. It looks like it has more flexibility than fixed one like DPUK sells. Where can I buy one similar?
Mine:
That is what I did.
Smile
