STD Tuning Engine What kind of throttle set up is this?
Torkey
Dirty Diesel
220
12-09-2014, 06:26 PM #1
I'm currently working on putting a OM617 turbo into a '79 300CD. The throttle set up is completely different from any other one I have seen.
Is anyone familiar with this set up and have suggestions on getting it t work with an engine/throttle set up from a 300SD?
79 300CD
82 300SD
Dirty Little Freaks Racing
Torkey
79 300CD
82 300SD
pryantcc
12-10-2014, 04:02 AM #2
Its not unlike the setup from my w108. What's the problem? All you need it to do is to pull the throttle lever on the pump somehow, right?
pryantcc
Tito
12-10-2014, 05:58 AM #3
Looks exactly like mine w114 and I'm pretty sure the w123 petrol has the same setup
Tito
12-10-2014, 06:23 PM #4
Early style linkage, yes. Completely retarded - no wonder they replaced it later Big Grin You need that bearing/bracket thingy on the firewall to change for the later style, can grab it at a pick'n'pull maybe. Needs welding/riveting/screwing to the firewall.
This post was last modified: 12-10-2014, 06:23 PM by DiseaselWeasel.
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
12-11-2014, 12:14 PM #5
[Image: om617_linkage-2.jpg]
[Image: om617_linkage-3.jpg]
^that's the later style less-retarded throttle linkage Big Grin
This post was last modified: 12-11-2014, 12:14 PM by DiseaselWeasel.
DiseaselWeasel
Torkey
Dirty Diesel
220
12-11-2014, 12:53 PM #6
(12-11-2014, 12:14 PM)DiseaselWeasel ^that's the later style less-retarded throttle linkage Big Grin
I agree about the old style linkage being retarded. Big Grin I'm going to try to convert it to the newer style.
This post was last modified: 12-11-2014, 12:54 PM by Torkey.
79 300CD
82 300SD
Torkey
79 300CD
82 300SD
12-11-2014, 01:08 PM #7
Well if you have in mind the old engines that went with this linkage - carburettor & vacuume-controlled IP; it does make sense to run it that way. But with the directly controlled key-start OM617 - it is sort of retarded to run it across the whole engine Big Grin
Don't know if the US market ever got those cars...!?
This post was last modified: 12-11-2014, 01:09 PM by DiseaselWeasel.
DiseaselWeasel
