my b@$t@rd coupe project.
ok, flame me, hate me, help me, whatever. this is my project and i will post my results as i have new ones.
list of goals, these are just random order as i think of them
1 large fmic this requires alot of cutting removal of front bumper and cut the crap out of the grill. and non arv turbo and clocked turbo, almost off the teal sd and will be clocked and put on the coupe
2 cool air intake thru pass hi beam.
3 get cut DVs back from machinist. ( my buddy who is machining them measured the collars and said they are 14 thousands wide and he will be taking 8 thousands off of them. he also said they are bhn of 62, which is hard as f**k! he is worried about them jumping out of the jig he made when he puts tool to steel!)
4 boost and egt gauges
5 lowered and kyb gas shocks
6 newer factory amg or benz rims
7 painted black
8 play with stock pump
9 fender dump exhaust
10 10mm plungers and barrels in an mw pump. i have talked to scheid diesel and they said they will put the plungers and barrels in a pump and flow bench it and calibrate for me for 1500. they sounded pretty sure they could do what ever i wanted to the pump. heck they said they would build a billet pump if i wanted to spend the cash! lol
11 lower geared rear end i think the coupe is running either 2.88 or 3.07s i have found conflicting info on what the 81 300d runs... so im not sure but if its 2.88s ill take the 3.07s out of the sd and swap them out.
12 4 spd swap out of a 240d n/a and hopefully the 3.69s? rear end
thats all i can think of for right now, i will update list as more comes to mind. i have already started mounting the intercooler, and was trying to have the ic mounted and the cut DVs in by scheid diesel fest but im having troubles finding 2.5 inch intercooler boots instock in town and will have to order the last 3 i need and it wont be functional by this weekend... the DVs were gonna be done by wensday but by buddies boss dumped some stuff that needs done asap and he may not get to them til next week...i really wanted to get a dyno run on just stock pump with cut DVs and ic... but i dont think it will happen by this weekend...
i have contacted the company that makes all the plungers and barrels but have not received an email back from them as of yet.
well here is a pic of the fmic mounted and the cooler piping started, i cant finish it until i have the other turbo clocked and mounted and have the rest of the boots to put everything together. so im kind of at a stand still... sniff sniff...
well thats really all i have for now, i hope to have it painted in a couple days, and if i can manage to fine some 2.5 intercooler boots ill finish the ic project. i will have dyno numbers to show what the stock DVs do and what the cut DVs will do, i will also have him do some full cuts and see if how it does. i have a few spare sets laying around so im not scared to lose a set over trial and error. i have less then 1k in the car, and less then 1500 in the car and all the mods i plan to do less the large pump. so cry that i cut up a nice coupe or not its my d@mn car ill do what i want to it. and i will try n post as much info as i can. i know the om617 is gaining more popularity and im not the only person looking for more power. the tech at scheid said that properly cut DVs should flow 10-20 more cc's of fuel and the 8 thousands im cutting off the first set should do something, he said he doesnt know how much more but it should flow a little more. I WILL find out.
lol intercooler!!! Keep us posted. waiting for more
For temp boots just get rubber elbows from home depot. They won't last very long but they whould be OK in a pinch.
You're not going to get flamed here, we like to blow shit up.
I think 8 thou is a little aggressive-I'd only knock off 4 thou from the DV's and see what happens
Can the diesel shop down there bore your injectors at all? If you're runing a huge pump but little teeny injectors will it be able to swueeze all the fuel through?
It's looking straigh Mad Max, sun
(08-20-2013, 09:50 AM)1911diesel ok, flame me, hate me, help me, whatever. this is my project and i will post my results as i have new ones.
(08-20-2013, 09:50 AM)1911diesel ...
Awesome stuff!
hummm well its all black, ill post a pic later when the camera is charged. as for the pump, well schied is known for building HI HP diesel engines, if they say they can build me a pump to do what i want i trust them. people come from hundreds of miles to have schied build their pumps injectors and engines. it may cost more but i bet i get a good pump done right. not saying that who ever you are suggesting isnt good at what they do. just i know schied knows their $h*t. i was told to use rubber rad line for temp but i dunno if i wanna do that either. i think i will wait for the boots and just leave it up for visual pleasure for now. maybe this weekend do the cool air intake thru the head light door and fender dump exhaust. i would really like to have it slammed before this weekend, but i couldnt figure out how to get the rear springs out with a spring compressor... there isnt enough room to get it in there to compress the dang spring! some help please???
oh and btw i LOVE blowing $h*t up! thats why i keep spare engines for anything i like! lol blow it up swap a new one in and dont do that again! lol
(08-20-2013, 03:45 PM)1911diesel . i would really like to have it slammed before this weekend, but i couldnt figure out how to get the rear springs out with a spring compressor... there isnt enough room to get it in there to compress the dang spring! some help please???
new pics! all black, BTW it was rattle caned, i normally wouldnt do this, i have been known to borrow a booth and paint it proper before but time constraints and all that, and most of all i wasnt sure how much longer i could handle that ugly a$$ brown/tan/gold color. i thought i was gonna puke if i had to look at it again.
oh and BTW i took both bumpers off! lol if he is still alive tell him that and see if he dies then...lol
ya know, for all this talk about the cut DVs and the rough idle, i have only found a few threads about it... every one seems to have the same general statement. rough idle high egts. i promise i have searched, and searched, and searched, google and here STD and have only found 5 threads that even mention cut DVs what am i missing? i know sometimes im r-tarded but please help this r-tard find some helpful info.
I know I would'nt care, but what does the police and shit say about that mounting in the front?
If you did that in norway, where I live, they probably would have suspended your driving license and give you a huge ticket :o
about a 1000$ or something :o
better then that i live in indiana, where the cops only care about meth... cars... ha! we dont even run emissions here! lol i plan on running the fender dump exhaust and i bet i never get pulled over for it. we run hood stacks and bumperless all the time round here!
BTW did a search for cut DVs instead of cut delivery valves and found a post from one guy who put the DVs in a lathe and did it right and he had lower egts but still a "lope idle"? is that the ruff idle every one is complaining about? you people know guys pay big money to have their trucks do that right? of course its not my daily, so i guess i wouldnt have to worry about it all the time...i think i could live with a lope, and if i had to, i could always make some poly engine mounts if it caused undue stress on engine mounts...i guess ill see when i get them back. someone also mentioned playing with the timing and pop pressure to correct some of the problems he was having. well im uber cheap, so until tax time and i have a stack or two to drop on a bigger pump i will make cut DVs work. i just wanna eat a honda or two!... or three....or four...
(08-21-2013, 02:42 AM)Ksteen2 I know I would'nt care, but what does the police and shit say about that mounting in the front?
(08-20-2013, 04:03 PM)JB3 Im pretty sure you can drop the whole rear subframe as a unit and make both springs loose at the same time if you don't have a compressor for the individuals.
Someone will have to verify, but I think a number of people have done it, definitely something to put in the search function here and over on PP. I remember reading it documented
(08-20-2013, 03:45 PM)1911diesel ... as for the pump, well schied is known for building HI HP diesel engines, if they say they can build me a pump to do what i want i trust them. people come from hundreds of miles to have schied build their pumps injectors and engines. it may cost more but i bet i get a good pump done right. not saying that who ever you are suggesting isnt good at what they do. just i know schied knows their $h*t. ....
(08-21-2013, 07:37 AM)1911diesel ...... well im uber cheap, so until tax time and i have a stack or two to drop on a bigger pump i will make cut DVs work. ...
(08-21-2013, 08:26 AM)Simpler=Better(08-20-2013, 04:03 PM)JB3 Im pretty sure you can drop the whole rear subframe as a unit and make both springs loose at the same time if you don't have a compressor for the individuals.
Spot on, you just unbolt the whole subframe and put it on jack stands. I added lift blocks in a parking lot (man was that a long night)
A lope really isn't good for an engine, but its really not bad either. People pay big bucks to make their truck sound like they are "loping" because all pulling trucks or tractors with giant pumps lope. A lope is combination between a big cam in the pump, big cam in the engine, and big injection lines.
It sounds cool, but its a pain for a daily driver.
And as far as DV's go, I would just make sure each one is super close to one another, like .001" at least. I could be wrong, but I would think it would mess up calibration of each cylinder. (make fueling to each cylinder different.)
well the guy i have doing the work is used to working in the half thou .0005 and i stressed how important it was that they were as close to the same as humanly possible. its basically a hi precision hi pressure fuel measuring and delivery device. he rebuilds hi precision hi flow roots blowers built for all kinds of applications. i have every faith in the man that he can preform the task at hand. I think it will be more on my end if it works out like i hope or not...
oh and not real worried about a daily, that is what the truck is for. the car has become all about fun. i have had a thing against hondas since high school (the fast and frustrated came out) and the honda boom got big, real big around here. gag.... ever since i have looked for obscure cars to have fun with.
then, the new york cops without guns are the cops i norway, you know, here you can drive 50cc "motor bikes" from you are 16, and we use too tune them back in the day, but now, you almost get court order for tuning, and they go 45 km/h original, thats desturbingly slow :o
little off topic
you car looks cool tho, unusual look :p
but cool
1911diesel well the guy i have doing the work is used to working in the half thou .0005 and i stressed how important it was that they were as close to the same as humanly possible. its basically a hi precision hi pressure fuel measuring and delivery device. he rebuilds hi precision hi flow roots blowers built for all kinds of applications. i have every faith in the man that he can preform the task at hand. I think it will be more on my end if it works out like i hope or not...
(08-22-2013, 02:56 AM)Ksteen2 then, the new york cops without guns are the cops i norway, you know, here you can drive 50cc "motor bikes" from you are 16, and we use too tune them back in the day, but now, you almost get court order for tuning, and they go 45 km/h original, thats desturbingly slow :o
little off topic
but cool
little off topic
but cool
i honestly think he could keep it within .0002 as well he has been machining for 30+ years. the only problem i see is i didnt keep their barrels matched. uh oh. but i think i have a way to fix that anyways. seeing as how there will be .008 of virgin steel at the bottom of the valve barrel that will never have had steel to it and the collars will have virgin steel as well i think im going to have him lap the valves into the barrels to "match" them to the new barrels. maybe even hit the out side of the barrels with some emery cloth. they were sitting in an old injection pump and they have some rust spots.i hope lapping the valves in to the barrels will create a good seal and i wont have to worry about fuel seeping by and causing off time injections.
(08-22-2013, 12:44 PM)1911diesel i honestly think he could keep it within .0002 as well he has been machining for 30+ years. the only problem i see is i didnt keep their barrels matched. uh oh. but i think i have a way to fix that anyways. seeing as how there will be .008 of virgin steel at the bottom of the valve barrel that will never have had steel to it and the collars will have virgin steel as well i think im going to have him lap the valves into the barrels to "match" them to the new barrels. maybe even hit the out side of the barrels with some emery cloth. they were sitting in an old injection pump and they have some rust spots.i hope lapping the valves in to the barrels will create a good seal and i wont have to worry about fuel seeping by and causing off time injections.
(08-22-2013, 08:45 AM)Simpler=Better 'MURICA RANT:
As long as you keep a muffler on the car, and don't do anything blantantly stupid, you can get away with pretty much anything vehicle wise around here. Until about 6 months ago, 50cc scooters DID NOT require registration, helmets, or insurance in Baltimore. It was awesome, like the damn wild west. Full motorcycles can get away with anything in MD, there is a no chase rule-so if the bike is going 90 in a 55 the cops turn on their lights but aren't allowed to chase. A buddy of mine was (supposedly) doing 140 in a 55, and actually stopped. The cop was so surprised he let him off with a warning. People also expect a bike to be loud, so straight pipes are fairly common on both 2cyl cruisers and 4cyl literbikes.
Bosch sure as hell didn't match them when they assembled the pump. Grab one fomr the bin, and put it in the pump.
Just clean them up with some mild scotchbrite and keep them oiled.
[/quote]
are you sure? i thought they should be kept together? i coulda swore i just read that somewhere yesterday, scared the piss outta me too and made me glad i hadnt pulled the ones out of the running car yet!lol... anyways maybe it will help, maybe not. i dont think it can hurt. just lapping compound and spinning them in the barrels with light pressure to seat them. they are i think he said 62 on the brinell hardness tester so i dont think it will take any material away.
well i got the cut DVs back! i slapped them in, and guess what! after i blew the air out it idled great! no problems! not much on the butt dyno but they have no problems!
here is a vid of the car running with the cut DVs and some black smoke. i didnt have any black smoke during driving, just during free rev. ill get to play with the car some more tomorrow but today i have to catch a nap and work tonight.
Glad to hear you got good results
What depth did you cut to?
he removed .008 from the collar going from bottom to top. he also told me if he never sees them again it will be too soon...lol but he gave me the jig he used to chuck them in the lathe. he said he gave me the tool he made to cut them as well but i dont see it... maybe he left it at work and thought he put it in the bag.
Great job. Sounds pretty good. Looking forward to hearing about the driving characteristics.
I am also wondering about how the performance end of it went for driving. I can't see why It wouldn't help!
well driving is pretty much stock, the first test around the block to blow out the air in the lines didnt do it justice. i drove it to work tonight didnt get on it too hard on the way there but early morning on the way home... damn... it pulls harder thats for sure. ill try n get a vid of it pulling 0-60. still proly not enough to smoke a boosted B series swapped honda... but it might be with some more playing. I must say i am fairly impressed. may not be worth a couple hundred bucks if i had to pay another shop to do the work. but if i could get them cut for 100 bucks or less they may be worth dropping in the couple that we drive on a daily. idle was a little shaky in gear with the break depressed. but not much. not enough to bother me. it almost sounds like its pulsing at cruse around 30. no feeling of pulsing just a faint sound maybe turbo pulse. i dunno ill have to do some more driving with them to find out. i know it will bark the tire just mashing the go peddle from a stop. and before it didnt wanna break the rear tire loose with out letting up off the break some, now once it gets to about 2k and the turbo kicks in the back tire breaks loose instantly. long story short, they were worth every penny i have in them...lol
how big elements have you got put in?
and what turbo?
Hmmm. Maybe my extra pump needs to be molested...
Does anyone know if N/A delivery valves are the same?
all stock, just cut DVs. i just wanted to see what cut DVs would to on a completely stock car.
man, i really, reeeeaaaaallllllyyyyyy wish i could get my machinist buddy to cut some more of these DVs. i would have him cut the other two stock sets i have so i could send them off to a couple of you guys for stock cores so you could try them and see what you think. but he wont touch another set. i have another buddy who is a machinist but he hasnt been doing it as long as Mark i guess all he can do is try. and the damn shake at idle is air in the damn lines again... the fuel lines going from the lift pump to the filter and the filter to the IP have been replaced 10 times now with every different kind and size of line i can find, hell i even used line inside line so i could clamp the out side hose with out cutting the hose thats holding pressure... and it still leaks after a day... it always stops for a day or two then it leaks after i get on it for a while. im tired of leaking diesel and chasing vacuum leaks... i just want the b*tch to shift without flaring, and stop wasting fuel... unless its in the form of black smoke... i will take some advice on what you guys think for fuel lines but if i cant get it to stop leaking soon, ill delete the IP mounted lift pump buy an electric fuel pump, new fuel filter setup and see if i cant get the b*tch to stop some other way... besides i think i read some where the stock lift pump doesnt have much pressure anyways what 10 psi or something anemic. i wonder if more fuel pressure pre IP would help as well.
(08-23-2013, 02:09 PM)1911diesel i just want the b*tch to shift without flaring
(08-23-2013, 09:23 PM)lgreeley83(08-23-2013, 02:09 PM)1911diesel i just want the b*tch to shift without flaring
Manual trans
Manual trans
No extra trans for sale. I know someone has one I forget who. I bought an extra about to months ago. Had more than one person reply having one for sale. Put a want to buy out there.
actually, i started looking after i said something about not being able to find one, and found a 75 240d 4spd i am looking at buying as of now! i will have the 3.69s i want and the 4spd and all the stuff for the swap! i hope i get it.
well cheap boost gauge, slime gauge. dunno where its gonna go permanent but its hooked up. i cant seem to get more then 10 psi with the mbc but with the wastgate unhooked its almost 20... dont do that anymore...lol not til i got an egt gauge anyways. ill be hooking that up as soon as i get the turbo off the other car. ill do manifold and turbo swap. tap and wrap the manifold with the probe. egr delete, wrap the turbo, and dump exhaust out of the fender with wrap... oh part of my fuel leak is fixed new o rings on the banjo bolt for the fuel filter. i kept trying to find the darn crush washer... but i guess its new style.. fuel lines from lift pump to filter still weep... but the line from filter to ip is good...i will figure this out. if not... i been looking into what cummins guys do. i guess 10-12 psi is good for even a cummins ip so if i do go electric fuel pump it wont take much. i kinda like the idea of an electric fuel pump anyways, no priming, and can be ran to a switch so if a run away occurs i can cut fuel off manually. well if i could just get the darn exhaust apart from the turbo on the teal SD i would be clocking the turbo and pulling the turbo off the coupe and finishing the intercooler set up. but alas it is still being a pain in my a$$... oh well break over back to work on something...
The "dream" fuel pump if from an F350, I don't know which model. I think forced ran one.
People have also had luck with the cheap inline 30psi pumps, just make sure there'a filter before the pump or you'll kill it.
Glad to hear of another cheapass boost gauge user
thanks do i need a block off plate for an electric fuel pump? or can i just run a line back to the lift pump itself? and thanks for the tip on the cheap a$$ boost gauge it works. makes me want a real one but this one is better then nothing and i have 10 bucks in it. oh and finally got the other turbo off, only to find it has way too much shaft play... oh well ill just use the non arv housing.ill order some intercooler boots this week along with an egt gauge/probe some oil filter gaskets for playing with the pump, and some fuel line. any one know the part # on PP for the fuel line that runs to the fuel filter from the lift pump?
First check the return fuel spring, it should be something like 22mm long or 27mm long-search for the spec that helps with fuel pressure issues.
Just use home depot nylon line, or regular fuel line for any of the connections. You can remove the old clear lines by heating them with a bic then pulling. DO NOT cut them, you will nick the banjo bolt and make a new leak.
Crush washers can be re-tempered with a small butane torch (or a propane torch). Or you can get an assorted box of copper crush washers from harbor freight and a "stepless" drill bit to make your own on the cheap. They're not that expensive from Mercedes/PP to begin with though.
For the electric pump you can plumb it through the lift pump or bypass it entirely with a blockoff plate, your preference.
(08-25-2013, 09:04 PM)Simpler=Better First check the return fuel spring, it should be something like 22mm long or 27mm long-search for the spec that helps with fuel pressure issues.
If you'e fucking around with all that spin on filter anyway you might look at a more in depth upgrade.
There's a thread on how to modify an oem filter housing to accept a bigger/cheaper filter from baldwin.
I've run some shady fuel and I can say that the upgrade has helped my fuel flow situation.
http://www.superturbodiesel.com/std/thread-176.html
Stretching the fuel return spring definitely helped my car, for sure. I'd recommend it to even people not looking for pure performance
well i think i found another leaking line... the rubber lines on the bottom of the tank look to be leaking as well... i get my truck back tonight, ill leave the coupe down put it under the knife for a while. need to replace some fuel lines change the compressor housing finish the intercooler play with the pump finish the exhaust change the breaks. but ill start on that tomorrow. im wore smooth the f*ck out today...
(08-20-2013, 11:52 AM)Simpler=Better You're not going to get flamed here, we like to blow shit up.
(08-20-2013, 12:25 PM)JB3 LOL, I just got off the phone with the classic center, and they are pissed that your 300CD has a painted on star on a non stock component, and wanted me to check to see if you altered the tire size or installed anything other than a factory radio.
I said you took the bumper off and I think the guy dropped dead right then.
(08-20-2013, 03:45 PM)1911diesel hummm well its all black, ill post a pic later
(08-20-2013, 03:45 PM)1911diesel i would really like to have it slammed before this weekend, but i couldnt figure out how to get the rear springs out with a spring compressor... there isnt enough room to get it in there to compress the dang spring! some help please???
(08-21-2013, 07:18 AM)MFSuper90 He's from the US, we don't give a sh*t!
(08-21-2013, 07:37 AM)1911diesel i think i could live with a lope, and if i had to, i could always make some poly engine mounts if it caused undue stress on engine mounts...i guess ill see when i get them back. someone also mentioned playing with the timing and pop pressure to correct some of the problems he was having. well im uber cheap, so until tax time and i have a stack or two to drop on a bigger pump i will make cut DVs work.
(08-21-2013, 07:37 AM)1911diesel i will make cut DVs work.
(08-21-2013, 04:18 PM)MFSuper90 A lope really isn't good for an engine, but its really not bad either. People pay big bucks to make their truck sound like they are "loping" because all pulling trucks or tractors with giant pumps lope. A lope is combination between a big cam in the pump, big cam in the engine, and big injection lines.
(08-22-2013, 08:45 AM)Simpler=Better1911diesel well the guy i have doing the work is used to working in the half thou .0005 and i stressed how important it was that they were as close to the same as humanly possible. its basically a hi precision hi pressure fuel measuring and delivery device. he rebuilds hi precision hi flow roots blowers built for all kinds of applications. i have every faith in the man that he can preform the task at hand. I think it will be more on my end if it works out like i hope or not...
If we cna hold 0.0005" on a craptastic abused old lathe you guys should be able to hold .0002" on a decend machine. It's more important that they're all the same-it will definitely effect balancing. If his tooling is having trouble with accuracy I'd suggestrunning some 1000# abrasive paper on flat bar to take the last little bit off.
(08-25-2013, 04:43 PM)1911diesel well cheap boost gauge, slime gauge. dunno where its gonna go permanent but its hooked up. i cant seem to get more then 10 psi with the mbc but with the wastgate unhooked its almost 20... dont do that anymore...lol not til i got an egt gauge anyways. ill be hooking that up as soon as i get the turbo off the other car. ill do manifold and turbo swap. tap and wrap the manifold with the probe. egr delete, wrap the turbo, and dump exhaust out of the fender with wrap... oh part of my fuel leak is fixed new o rings on the banjo bolt for the fuel filter. i kept trying to find the darn crush washer... but i guess its new style.. fuel lines from lift pump to filter still weep... but the line from filter to ip is good...i will figure this out. if not... i been looking into what cummins guys do. i guess 10-12 psi is good for even a cummins ip so if i do go electric fuel pump it wont take much. i kinda like the idea of an electric fuel pump anyways, no priming, and can be ran to a switch so if a run away occurs i can cut fuel off manually. well if i could just get the darn exhaust apart from the turbo on the teal SD i would be clocking the turbo and pulling the turbo off the coupe and finishing the intercooler set up. but alas it is still being a pain in my a$$... oh well break over back to work on something...
Side note-a loping engine is usually setup for high RPM power. The idle lope is a side effect because the engine's timing is tuned so much for the high side that it can barely stay alive down low. They let it lope at idle because running in a smooth rpm would cause it to overheat and would be louad as shit. No one likes a 3,500rpm idle
well i was just trying to make it different for the diesel after party... and it stood out. besides that, i have been waiting on some parts i ordered, gaskets, seals, tranny filter and gasket, shifter bushings, and some other things. hopefully they will be in tomorrow. even still i just ordered a pop tester it should be here in a couple weeks. and sunday... well sunday i have a trip north to pick up another coupe. hopefully. fingers crossed... its not running, but i hope that this one like the last few non running diesel benzs i have acquired were owned by "non diesel mechanics" and were fairly simple fixes. if that proves to be the case again, ill drive it daily and leave the other coupe under the knife. but its a 78 non turbo, i dont know how long it will stay with a n/a engine im already thinking about pulling the engine out of the sd and i dont even have the car home!
(09-05-2013, 07:11 PM)1911diesel well i was just trying to make it different for the diesel after party... and it stood out. besides that, i have been waiting on some parts i ordered, gaskets, seals, tranny filter and gasket, shifter bushings, and some other things. hopefully they will be in tomorrow. even still i just ordered a pop tester it should be here in a couple weeks. and sunday... well sunday i have a trip north to pick up another coupe. hopefully. fingers crossed... its not running, but i hope that this one like the last few non running diesel benzs i have acquired were owned by "non diesel mechanics" and were fairly simple fixes. if that proves to be the case again, ill drive it daily and leave the other coupe under the knife. but its a 78 non turbo, i dont know how long it will stay with a n/a engine im already thinking about pulling the engine out of the sd and i dont even have the car home!
(09-06-2013, 08:31 AM)Simpler=Better(09-05-2013, 07:11 PM)1911diesel well i was just trying to make it different for the diesel after party... and it stood out. besides that, i have been waiting on some parts i ordered, gaskets, seals, tranny filter and gasket, shifter bushings, and some other things. hopefully they will be in tomorrow. even still i just ordered a pop tester it should be here in a couple weeks. and sunday... well sunday i have a trip north to pick up another coupe. hopefully. fingers crossed... its not running, but i hope that this one like the last few non running diesel benzs i have acquired were owned by "non diesel mechanics" and were fairly simple fixes. if that proves to be the case again, ill drive it daily and leave the other coupe under the knife. but its a 78 non turbo, i dont know how long it will stay with a n/a engine im already thinking about pulling the engine out of the sd and i dont even have the car home!
sweet.
I'd look it over, and tow it home. If you slap in a new battery and filters, then start it up before the sale the owner will want more
sweet.
(09-06-2013, 03:20 PM)1911diesel(09-06-2013, 08:31 AM)Simpler=Better(09-05-2013, 07:11 PM)1911diesel well i was just trying to make it different for the diesel after party... and it stood out. besides that, i have been waiting on some parts i ordered, gaskets, seals, tranny filter and gasket, shifter bushings, and some other things. hopefully they will be in tomorrow. even still i just ordered a pop tester it should be here in a couple weeks. and sunday... well sunday i have a trip north to pick up another coupe. hopefully. fingers crossed... its not running, but i hope that this one like the last few non running diesel benzs i have acquired were owned by "non diesel mechanics" and were fairly simple fixes. if that proves to be the case again, ill drive it daily and leave the other coupe under the knife. but its a 78 non turbo, i dont know how long it will stay with a n/a engine im already thinking about pulling the engine out of the sd and i dont even have the car home!
sweet.
i know how that goes. i always wait til i get them home before i mess with them. i dont mind ratcheting them onto the trailer then driving them off when i get home after playing with them for a few... my parts came in today! yay! now to find time to work on it... lol oh and after more emails with the china company that does the big elements, they want 2.20USD pr nozzle and no minimum order on nozzles! so i guess ill be ordering elements and nozzles at the same time to save some cash on shipping.
sweet.
