STD Tuning Engine Stock OM617 non turbo convert turbo
jarow123
07-26-2013, 09:27 AM #1
Hello I'm new here, I'd like to ask I would like to mount the turbo on OM617 non turbo. Turbo pressure would be 0.6 bar so low pressure engine should handle it. I know that assembled STT turbo kits that ran on this principle. Motor would handle such loads?
jarow123
07-26-2013, 09:30 AM #2
It should be fine at that pressure. But don't expect much power improvement with out tuning the injection pump
jarow123
07-26-2013, 01:31 PM #3
I meant is that I add a piece turbo pump is adjusted so it should be fine right?
jarow123
07-26-2013, 02:24 PM #4
If you swap on a turbo pump yes you can make more power easily. The MW pump has an external oil line, don't forget to connect it.
An EGT gauge can help you get more power safely without melting the engine. I don't know what the limit for a naturally aspirated 617 is, but the turbo version's limit is 1250°F
This post was last modified: 07-26-2013, 02:34 PM by Simpler=Better.
jarow123
07-27-2013, 01:20 PM #5
I have M pump thats better or MW pump ?
jarow123
07-29-2013, 11:06 AM #6
The MW pump was the stock turbo pump in the USA. Bolt on for turbo application.
The M pump was the stock naturally aspirated pump in the rest of the world. Can be tweaked to put out more power, may need to be tweaked by a shop-I don't know how much you can improve it without sending to a shop. Dieselmenken is the expert with M pumps
