will these tires fit?
http://www.performanceplustire.com/produ...D%5B%5D=27
will a 215x75x14 fit on a bundt?
I am about to run out of rubber and wanted to order these asap. How can I tell if the width of these is compatible? I was at walmart today to find out that a crap load of steel was popping out of one tire and it was about to blow and another is not far behind. All a result of that stupid control arm bushing.
I do not know from experiance, but i think they would.
The biggest ive had on a bundt was i think 205/70-14.
I dont remember Captain Americas tire size on his red w123, but he has some gnarly offroad tires on there..
Well they are narrower right? at 75 instead of 70. Will I be able to have a shop mount them? I am thinking so but, I would hate to be stuck with some tires that I can't use.
(04-02-2011, 02:27 PM)larsalan Well they are narrower right? at 75 instead of 70. Will I be able to have a shop mount them? I am thinking so but, I would hate to be stuck with some tires that I can't use.
195/70/14 I just wonder will this tire mount on the rim. Can only afford 2 for the rear right now. Can't even really afford that but, I guess I'll have to. That new tire size is 2 in larger diameter so 1 in bigger radius I don't see how that could be a problem. Just that I don't understand width of the rim and tires.
from what I can gather they will fit on the rim
http://www.peachparts.com/shopforum/arch...23331.html
http://home.seebz.com/redirect.php?tid=3...o=lastpost
